Is it possible to get it rounded
UltraButton has rounded corners by default. At least on Windows Vista it does - I'm not sure if it's different on Windows XP. And I am testing with v7.3.
You can also make the button any shape you want via the ShapeImage property.
Thanks Mike
I'm working on Windows XP with turned off all styles and in that mode button is displayed as rectangleI'm interested to have same look as using Windows XP Styles
Thanks for tip re share - had not idea I coud format it that way!
BTW I think it would be great if you could add OS-styles independent rouned button look
Maciej
Hi Maciej,
I can't remember how we implemented it. But my guess is that the rounded buttons are drawn using the Windows theming API. So that API is not available on Windows XP. We could, of course, create our own implementation to mimic it and thus support the rounding on XP, but it looks like we are currently not doing that.
You should Submit a feature request to Infragistics
