We have a design-time license problem on one of our machines.
NetAdvantage 2007 v3 + hotfix 1043
Visual Studio 2008
licenses.licx contains many lines
we can't build project on THAT machine with this licenses? however we CAN build if we empty licenses.licx
what should we do to override?
And we CAN'T drop the contents of licenses.licx entirely for we have many developers
Unfortunately, I believe this is the only solution to the problem; I'm fairly certain that this problem stems from the .NET licensing mechanism. Since I don't think there is any downside to clearing the contents of the file, why is it not a solution to simply clear out this file for everyone? Are the versions the same on all machines? Are any DLLs copied locally that don't match the version referenced in the projects?
-Matt
