Hii.
I want to know how can i create a Dynamic Ribbion Control on a particular Tab or Group using the SQL Server.
Can any1 help me out in this issue..
The toolbars manager and ribbon have no relationship with data bases and you cannot data bind the ribbon to create ribbon tabs and tools based on the contents of a data base. Any work like this would have to be implemented manually by your application. However, you can save the layout or a toolbars manager to a stream and store that in a data base as a binary or xml value. Then you can load that layout stream from a data base and load it into the toolbars manager. But it will just revert back to a previous ribbon configuration. You cannot use this to dynamically create a ribbon.
