1175
Formatting Calculated Values
I create a column, set its formula and set its data type
this.createdColumn = this.band.Columns.Add( columnName );
this.createdColumn.DataType = (Type)item.DataValue;
this.createdColumn.Formula = this.ultraTextEditorFormula.Text;
Then I call Recalc
UltraCalcManager ucm = (UltraCalcManager)this.createdColumn.Layout.Grid.CalcManager;
ucm.DeferredCalculationsEnabled = false; ucm.ReCalc();
ucm.DeferredCalculationsEnabled = true;
Now for my problem, if I set the column datatype to Int32 and create a calculation that is between 2 decimal columns, the formula results show a decimal value. Is there anyway to format the values to make them an int or to round a decimal to a certain number of decimal places?
Version 2006.1
Thank you, Jamie
