I have an Ultragrid control that is bound to a UltraComboEditor(value2 as per code). It has been used since I need to enable multiple value selections and values to be seperated by ",".Filter row for this column seems to take bit of time (even for row count>500) and is unresponsive for large row count. I compared the same with dropdown with a valuelist that works for large number of rows. Can someone help on the same
private void _ListGrid_InitializeLayout(object sender, InitializeLayoutEventArgs e){ ValueList vl = new ValueList(); for(int i=1;i<=6000;i++) { vl.ValueListItems.Add(i.ToString()); } //to check:value as dropdown _ListGrid.DisplayLayout.Bands[0].Columns["Value"].ValueList = vl; _ListGrid.DisplayLayout.Bands[0].Columns["Value"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
DataTable dt = new DataTable("MyTable"); DataColumn idColumn = new DataColumn("ID", typeof(int)); dt.Columns.Add(idColumn); DataColumn nameColumn = new DataColumn("Name", typeof(string)); dt.Columns.Add(nameColumn); // Set the primary key column dt.PrimaryKey = new DataColumn[] { idColumn }; //to check:any value greater than 500 cauing delay with filter row for Value2 column for (int i = 1; i <= 6000; i++) { DataRow dtChld = dt.NewRow(); dtChld["ID"] = i; dtChld["Name"] = i; dt.Rows.Add(dtChld);
} this._cmbUseCase.DataSource = dt; this._cmbUseCase.DisplayMember = "Name"; this._cmbUseCase.ValueMember = "ID"; //to check:value 2 as UltraComboEditor mapped to ultrgrid _ListGrid.DisplayLayout.Bands[0].Columns["Value2"].EditorComponent = _cmbUseCase; _ListGrid.DisplayLayout.Bands[0].Columns["Value2"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.FormattedText;
_ListGrid.DisplayLayout.AutoFitStyle = Infragistics.Win.UltraWinGrid.AutoFitStyle.ResizeAllColumns; _ListGrid.DisplayLayout.Override.FilterUIType = FilterUIType.FilterRow;}
Hello Jesuraj,
I have been investigating into the behavior you are seeing, and I have reproduced the performance issues you are seeing with the UltraComboEditor within the filter row.
This behavior is unexpected, and as such, I have asked our engineering teams to examine it further. To ensure that this receives attention, I have logged it in our internal tracking systems with a development ID of 29661. The next step will be for a developer to examine this issue further and offer a fix or other resolution.
I have created you a private support case so that you can be notified when this happens. This support case has an ID of C-00235362, and you can access it after signing into your account here: https://account.infragistics.com/support-cases.
