I have an appointment displayed on an UltraMonthViewSingle and an UltraDayView. The appointment is NOT an all day appointment so it has a start and end time. In the UltraDayView control, I can expand the appointment so that the start and end are on different days, but I do not seem to be able to do this in the UltraMonthViewSingle control.
Any appointment that already starts and ends on different days can be resized in the UltraMonthViewSingle control, but if I resize it to a single day, then I loose the ability to resize it there, and can only do so if I switch to the UltraDayViewControl and do it there.
Is there a way I can enable resizing the appointment in the UltraMonthViewSingle control when the start and end are on the same day?
I am open to using CreationFilters, or other similar things, or even Reflection to enable this.
I appreciate any assistance that you can give.
Thank you.
Hello and thank you for contacting Infragistics. The MonthViewSingle, out of the box, allows you to resize by left-clicking the edge of the appointment and holding the mouse down to resize the appointment across multiple days. This allows you to go down to additional weeks if need be to further extend out the appointment as long as you started dragging on the right side. Otherwise it will move it to another day. If you want to extend out an appointment to days prior you would have to start dragging from the left side of the appointment. I attached a demo of this.
I appreciate the video. Thank you.
I notice that in your version, the appointment is a rectangle and has no resize handles, whereas mine has rounded edges, and has resize handles only when it starts and ends on different days.
Is yours an all day appointment? I think I read somewhere that all day appointments can be resized.
Could some property have disabled this resize functionality? I have not found anything as yet.
If you have any ideas, I would be most appreciative to hear them.
If not, then I will try to create a sample project to demonstrate my problem.
