Hi,I'm using UltraToolbarsManager and UltraToolbarDockArea which i'm using for a ribbon. When I'm using ShowDialog() I want to my UI to be blocked until an user finish his actions on showed form. Generally it works fine, but there is a problem when we are using remote session, if an user got disconnect and then reconnect to session then my ribbon losing his modality, other areas are still blocked but the ribbon is available. I've checked minimal repro scenario with simple ShowDialog to check if it is maybe an issue of Winforms, but after deeper investigation I've noticed that it's possibly related with UltraToolbarsManager FormDisplayStyle -> StandardWithRibbon, I've checked other style and modality of ribbon is preserved after reconnecting
Hello and thank you for contacting Infragistics. These kind of remote desktop issues come up here and there and the first thing we recommend you try is turning off IsGlassSupported = False on the toolbarsmanager.
A similar issue and recommendation was previously discussed here:
https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/119592/remote-desktop-disconnect-reconnect-tx-textcontrol-losing-all-but-plain-text/530661
Let me know how this goes and if you have any questions.
