I don't speak your language so I hope you will understand.
I have a list of objects that contains another list of objects.
To clarify the scenario
Object 1:
Public Class FaseReport
Public Property Descrizione As String Public Property TipoEsitoAzione As enumTipoEsitoLog Public Property ReportListaStep As List(Of LogReport)
Public Sub New() _ReportListaStep = New List(Of LogReport) End Sub
Object 2
Public Class LogReport
Public Property Quadro As String Public Property Campo As String Public Property ValoreInserito As String Public Property ValoreAtteso As String
Public Property Messaggio As String
End Class
I populate these object and Bind them to an UltrawinGrid so I obtain something like this:
My question is: is it possible to hide a column or change its name according for example to the content of the row i marked in yellow? what I mean is if the row contains the word SCRITTURA i would like to hide a Column but only for its childs and kepp on seeing it in the second group where the row contains the word LETTURA. Or under other conditions change the column name. What happens is that if I make a change trying to match the conditions in the InitializeRow event ,changes are reported in all the group band.
Hope you understood.
Thank you
Adolfo
You cannot easily hide a column on a row by row basis. This was previously discussed here:
www.infragistics.com/.../showing-hiding-a-column-in-an-ultragrid-on-a-row-by-row-basis
You can access the header caption by using the row's cells collection and accessing the column.
eg.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/53279/getting-ultragrid-column-names
Hi Michael,
thank you for your prompt reply, The link you provided seems to match exactly my scenario, even if unfortunately it seems there is no easy solution.
