15
InfragisticsWPF4.Chart v10.3 - When setting Y axis Unit value from range [0.1 -- 1.] chart is not able to create range with 2 or more decimal places - rounds to 1 decimal place number.
Hello.
WPF project, targeting 4.7.2 .NET Framework version.
We are using InfragisticsWPF4.Chart v10.3.
We created line chart.
When setting Y axis Unit value from range  [0.1 -- 1.] it is not able to create range with 2 or more decimal places - rounds to 1 decimal place number.
Using 2 or more decimal places. Y axis values are rounded to nearest 1 decimal place number.
Example.
A [issue]: when set unit=0.25, min=0, max=1 then it will display  y values: 0.3; 0.5; 0.8; 1.0
B: issuewhen set unit=0.24, min=0, max=1 then it will display  y values: 0.2; 0.5; 0.7; 1.0
C [works fine]: when set unit=0.05, min=0, max=1 then it will display  y values: 0.05; 0.10; 0.15; 0.20;...
D [works fine]: when set unit=1.111, min=0, max=10 then it will display  y values: 1.111; 2.222; 3.333;...
In our code I do not see any issue - Unit value is set for Axis options - so looks like it is Chart control issue.
Did not tried latest version...
Any comments or you are aware about such issue.
Parents
No Data
Reply
  • 7375
    Hello Vidmantas,
    Thank you for your post . I am little confused here , you posted the question under Windows Forms but you mentioned WPF dll , so may I know which platform chart you are using WinForms or WPF?
    Please keep in mind version 10.3 is no longer supported , we may or may not had an issue ,.
    You have to confirm by running the sample against latest version 21.2/22.1, if we still find the issue we can investigate it further.
Children
No Data
