Hi there,
I am trying to scale icons, images and font size on the toolbar manager. I have scaled the images manually on the icons and font size is scaled depending on the Dpi change. I was wondering the file menu and other tabs on the toolbar manager can be scaled or
what would be the best method of scaling as I have one 4k monitor?
Example is similar to my app:
Deep
Hello and thank you for contacting Infragistics. DPI scaling for the UltraToolbarsManager is considered to be a new product idea.
You can suggest new product ideas for future versions (or vote for existing ones) at <www.infragistics.com/.../ideas>. Submitting your idea will allow you to communicate directly with our product management team, track the progress of your idea at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you. Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it.
