All I have on my form is the UltraToolbarsManager with the NavigationsToolbar visible property set to true.
I add a container control to the navigation toolbar and point the 'Control' property to an ultraTextBox. When I run my app, i can never see the text in that textbox control. I can click in that text box and select the contents and paste it into notepad, so KNOW there is text there but it cannot be seen. Doesn't matter what control I put in that navigation toolbar, I cannot see its text.
I'm using Infragistics Ultimate 18.2, Visual Studio 2019, and doing this all in C# in a Windows 10 environment.
HELP!! :-)
Please set IsGlassSupported to false. This is a mutually exclusive behavior between the OS and the control. Glass can only be extended onto a main-level form, so this will not have an effect on a child mdi form or a user control.
this.ultraToolbarsManager1.IsGlassSupported = false;
Wow. Simply wow. That worked. Thank you!!!!
