Is there a way to set custom text on an UltraPieChart Tooltip? I can handle the TooltipContentUpdating but it does not return a control like on the UltraDataChart which I am more familiar with. When I use the UltraDataChart I typically return a custom formatted label which works great and allows for a lot of flexibility. I would like to at minimum set some custom text to show when you hover over each slice of the pie. Is that possible? Can the UltraDataChart render a Pie Chart?
Hello Nicholas,
It is definitely possible to set custom text for an UltraPieChart tooltip, and this is done using the TooltipContentUpdating event of the control.
I am guessing that you are perhaps on an earlier version of the Infragistics for Windows Forms toolset if the TooltipContentUpdating is not returning a Control? At the time of writing this, the event arguments of the TooltipContentUpdating event exposes a CurrentContent property that returns a Control, which you can either dig into or replace with your own control.
I am attaching a sample project that demonstrates the usage of this event to show a custom tooltip text for the different slices of an UltraPieChart.
UltraPieChartTooltip.zip
Thanks, I think what was throwing me off was assigning it through the event args rather than the event actually returning the control directly. This works and I appreciate you providing this guidance and sample code.
