Hello, I do use Infragistics 16.1 Win CLR4x. In my WinForms application I use the UltraGrid element. There I have activated the option for filtering in the first row. The values to filter in the individual columns now appear as DropDown. I would now like to select multiple values in these DropDowns. Preferably with a checkbox in front of each value. Is such an implementation possible? If yes, then how?
Ali
Hello Ali,
Thank you for posting. I believe you are talking about Excel style filtering, which you can achieve by using our ultraGridFilterUIProvider component.
I would recommend you to follow this document for detail information:www.infragistics.com/.../wingridfilteruiprovider-enabling-enhanced-filtering-on-wingrid
Let me know if you have any question.
Thank you sir. This works fine for me.
