I am assigning a dataset to an ultragrid, but my dataset has many records, and the assignment takes too long, about 5 minutes for 50k records. It is a dataset with 3 related tables.
How can I decrease this time?
I have infragistics v8.2 installed
Hello Gerardo,
Thank you for your post.
You are using version 8.2 which is no longer supported. I would recommend you to test the sample against latest supported version 19.2 and let me know if it still taking long to load the data.
In addition here is the performance guide of UltraGrid ,if you want to have a look.
Regards,Divya Jain
