I have a Quick Access toolbar and some contextual tabs. I have two tools on the QAT by default and when none of the contextual tabs are visible both tools are displayed. When a contextual tab is displayed, the QAT collapses down to 1 tool. Is there a way to specify the minimum collapsed size of the QAT, or a minimum number of controls to display?
Is the contextual tab group header blocking the QAT from displaying the 2nd tool. If so, this is correct behavior, because the header must display as much as possible and the QAT cannot overlap it. However, if the tab group header is off to the right far enough that the QAT can easily display both tools, it is a bug and I would recommend submitting it to the support group: http://www.infragistics.com/gethelp.
I am also having the same issue. I have two modules in my appication and based on the selection it will show me the appropriate tabs. The tabs are grouped using ContextualTabGroup and I made the ContextualTabGroup caption to none. It has enough room space to show all the QAT tools on one row but still the QAT is showing only one control and showing the pointer to the secondrow. Please let me know how to set the width of the QAT.
Suresh
The width of the QAT cannot be set and it automatically determined based on its content and the content of the Ribbon. Can you post a screenshot of the problem you are seeing? I just want to make sure I understand the problem you are having. Thanks.
