165
cannot get a datatable data to display in ultradatachart
I am trying to create an ultradatachart that should show 8 or 9 lines from a datatable.
The x axis should show the date column "dtg" and the Y values should come from the "tagvalues" column.
here is my code so far:
using (MySqlDataAdapter da = new MySqlDataAdapter(sql, con))
                        da.Fill(dt);
                        var data = dt.AsEnumerable() // convert the data to Enumerable so you can use linq over it
                        .Select(r => new { dtg = r["DTG"], tagname = r["TagName"], tagvalue = r["TagValue"] }) // convert data to list of anonimous objects
                        .GroupBy(d => d.tagname, (key, value) => new { key = key, value = value.ToList() }) // group the data by line names
                        .ToArray();
                        ultraDataChart1.Series.Clear();
                        ultraDataChart1.Axes.Clear();
                        ultraDataChart1.IsHorizontalZoomEnabled = true;
                        ultraDataChart1.IsVerticalZoomEnabled = true;
                        var xAxis = new CategoryDateTimeXAxis
                            Label = "Label",
                            DataSource = dt,
                            DataMember="dtg"
                        var yAxis = new NumericYAxis();
                        ultraDataChart1.Axes.Add(xAxis);
                        ultraDataChart1.Axes.Add(yAxis);
                        foreach (var x in data)
                            AreaSeries useries = new AreaSeries();
                            useries.XAxis = xAxis;
                            useries.YAxis = yAxis;
                            useries.ValueMemberPath = "tagvalue";
                            useries.DataSource = x.value;//.Select(a => a.tagvalue).ToArray();
                            ultraDataChart1.Series.Add(useries);
I cant get it to show the data.
Any help would be greatly appreciated.
Parents
  • 25665
    Verified Answer
    Hello Paul,
    You are having issues seeing the chart render because you are anonymizing the data. If you really want to do that you can use a dictionary. Otherwise if you want to see binding to different datasources you can look in our samples browser XamDataChart > Data > Binding Data Types.
Reply Children
No Data
