I am checking the value of each cell in the exporter event. I've defined different columns as different data types. For some reason, though, the code
e.CurrentWorksheet.Rows(e.CurrentRowIndex).Cells(e.CurrentColumnIndex).CellFormat.FormatString = "$#,##0.00"
doesn't seem to be working. In debug, I see it enter
Case "Currency" Dim exportvalue As Decimal If Decimal.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue e.CurrentWorksheet.Rows(e.CurrentRowIndex).Cells(e.CurrentColumnIndex).CellFormat.FormatString = "$#,##0.00"End If
However, a number like '65.0' will remain like that in the spreadsheet, instead of looking like '$65.00".
Is the cell not updated yet? Do Ihave to do the formatting later, after the fact, and if so, how and where - how can I manipulate the spreadsheet after it's exported (office is not on this server), or is this the right place, and I'm just doing something wrong?
Thanks.
Here's the entire exporter event routine.
Private Sub UltraGridExcelExporter1_CellExporting(sender As Object, e As ExcelExport.CellExportingEventArgs) Handles UltraGridExcelExporter1.CellExporting
Dim colptr As Integer Dim skipit As Boolean = False Try colptr = e.GridColumn.Index Catch ex As Exception skipit = True End Try If Not (skipit) Then Dim datatype As String Try datatype = datatypeline.Split(Param_Delim)(colptr + 1) Catch ex As Exception End Try Try Select Case datatype Case "Int16" Dim exportvalue As Int16 If Int16.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "Int32" Dim exportvalue As Int32 If Int32.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "Int64" Dim exportvalue As Int64 If Int64.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "Decimal" Dim exportvalue As Decimal If Decimal.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "Double" Dim exportvalue As Double If Double.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "Currency" Dim exportvalue As Decimal If Decimal.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue e.CurrentWorksheet.Rows(e.CurrentRowIndex).Cells(e.CurrentColumnIndex).CellFormat.FormatString = "$#,##0.00" End If Case "Date" Dim exportvalue As Date If Date.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case "DateTime" Dim exportvalue As DateTime If DateTime.TryParse(e.GridValue.ToString, exportvalue) Then e.ExportValue = exportvalue End If Case Else End Select Catch ex As Exception End Try End If
End Sub
Hello Samuel,
It appears from the code that you have provided that you are performing your cell formatting in the CellExporting event, which may be slightly too early. Rather than doing this, I would recommend doing your formatting in the CellExported event, as this event will fire after the cell has finished exporting and allow you to format the already-existing value in that cell.
Sincerely,AndrewSoftware Developer
Worked like a CHARM! I suspected something like that, but forgot to check for other events on the exporter control!
Thanks!
