I am creating a custom datasource where I create a Data Table with 5 columns and pre-populate the data. One of the columns stores an ID value from another table (ContainerID) and I would like to have that column as a dropdown with the available Containers. I get this data table in another data pull and mostly everything works fine except on the initial viewing of the grid. See code below.
As you can see below, the data initially has a value of 3. How can I get it to show the description instead, like in a normal combo?
I tried the bindingvaluelist and a regular valuelist, both had same results.
rTable = GetContainerTable() ugvContainers.DataSource = rTable If ugvContainers.DisplayLayout.ValueLists.Contains("Containers") Then ugvContainers.DisplayLayout.ValueLists.Remove("Containers") End If Dim vList as Infragistics.Win.ValueList = ugvContainers.DisplayLayout.ValueLists.Add("Containers") Dim cTable as Erp.BO.ContainerHeaderListDataSet.ContainerHeaderListDataTable = GetContainerDataSet() For Each dr as DataRow in cTable.Rows vList.ValueListItems.Add(dr("ContainerID"), dr("ContainerDescription")) Next Dim bvl as Infragistics.Win.BindableValueList = New Infragistics.Win.BindableValueList() bvl.DataSource = cTable bvl.ValueMember = "ContainerID" bvl.DisplayMember = "ContainerDescription" bvl.BindingContextControl = ugvContainers ugvContainers.DisplayLayout.Bands(0).Columns("Cont").ValueList = bvl ugvContainers.DisplayLayout.Bands(0).Columns("Cont").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList ugvContainers.DisplayLayout.Bands(0).Columns("Cont").Width = 200
Hello Mike,
I have created a sample project based on the code that you have provided, and at the moment, I am unable to reproduce the behavior you are referring to, as the BindableValueList.DisplayMember is showing through in the UltraGrid's DropDownList column. I am not entirely sure as to why this is not working for you, but perhaps it is a difference in the Infragistics for Windows Forms versions we are using, or perhaps a misunderstanding of your requirement on my end?
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 17.2.20172.1000 in Infragistics for Windows Forms 2017.2.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
6371.UltraGridDropDownDisplayVB.zip
Sincerely,AndrewAssociate Developer
So I have figured the problem out. It seems the control works. I had a valuemember in the field that was not in the combo valuelist. When I changed the value on the data and reloaded the form, it displayed correctly.
