We have successfully got our UltraComboEditor control to display images on our grid (a blank, a green blob and a red blob) that matches with data in an UltraDataSource. The column filter is just a straight equals (so is hidden) and we have the dropdown showing the same 3 images. However, once the filter is applied (and that works too), the image is chopped off so we get just the smallest edge - maybe a couple of pixels of the image, then some white space which looks like we could type into it and that's it.
How can we get the whole image to show ? Is there some kind of text entry that's being displayed that we can disable ?
thanks
Andy
We are only on Infragisticis4 v13.1 due to our current technical requirements, so maybe there's something changed to the version that's current.
All looks good so far. Only other issue is that I can't set a column format to be HH:mm, I set it and it ignores it. Field is mapped correctly as DateTime. Not the end of the world but would be nice as it's been picked up in UAT.
thanks again,
Hi Andy,
Ah, I didn't realize you were using such an old version. Now that you mention that, I think I remember that there might have been a bug in the FilterCell that caused it to show extra text like what you have in your screen shots. I thought it was fixed a long time ago, but maybe it still existed in v13.1.
As for the Format not working, Format only affects the display when a cell is not in edit mode.
One reason why the format would not work is if the column is the wrong data type. You can't format a string column, for example.
Another is if you are setting the CellDisplayStyle on the column to a setting that disables formatting.
