Is there a way to customize the ribbon in such a way that the little arrow beside the Quick Access Toolbar is hidden?
Remus
I don't think there is any property that will do this automatically. However, you can try to implement a creation filter that removes a QatQuickCustomizeToolUIElement from its parent element (which I believe is RibbonCaptionAreaUIElement) when the ribbon elements are being positioned. If you are new to creation filters, this article should help you get started: http://help.infragistics.com/Help/NetAdvantage/NET/2007.3/CLR2.0/html/Win_Creation_Filter.html
I add tools to this and it removes the tools I had added in the designer
in addition--doing this does not, and I can find no way to ,show the quick customize button displayed at the end of the QuickAccessToolbar
[Visual Basic]
