2290
disable and gray out IGSlideTabItem
Is there a simple way to disable/enable TabItem so that when it is disabled it is grayed out and normal when enabled?
Thank you
Mark
Parents
  • 4940
    Suggested Answer
    Hi Mark,
    There's not an automated way to do this, but assuming you're using the default tabs it can be done with a few lines of code. On the instance of the IGSlideTabItem you can set the tabColor property to make it appear grayed out and if necessary you can also configure the text label to your liking through the tabLabel property.
Reply Children
No Data
