Hi all!
I would like to use NucliOS 2013.1 in a Xamarin.iOS project but I'm stuck with a problem. I can't find out how set custom labels on the X-axis for a given data points in a series. I tried to implement a custom data source class and implemented the ResolvePointAtIndex method. However, the IGDataPoint defined in IGChart.dll does not contain a Value property, it only has a Label property. So using this approach I can set the label, but not the value - which results in a runtime exception. Am I missing something? Are there any alternative approaches?
ThanksMarkus
To customize axis labels, you override the ResolveLabelForAxis method in a class that derives from IGChartViewDelegate. The code below populates an array of custom data objects and customizes both the x and y axis labels of a column series chart.
namespace ChartCustomDataAxisLabels{ public class GraphObject : NSObject { [Export("Territory")] public String Territory {get; set;} [Export("Cost")] public Double Cost {get; set;} public GraphObject() {} } public class ChartViewDelegate : IGChartViewDelegate { public override string ResolveLabelForAxis (IGChartView chartView, IGAxis axis, NSObject item) { if (axis.Key.Equals("xAxis")) { return ((IGCategoryPoint)item).Label; } else if (axis.Key.Equals("yAxis")) { NSNumberFormatter formatter = new NSNumberFormatter(); formatter.NumberStyle = NSNumberFormatterStyle.Currency; return formatter.StringFromNumber((NSNumber)item); } return String.Empty; } } public partial class ChartCustomDataAxisLabelsViewController : UIViewController { IGChartView _chart = new IGChartView(); List _data = new List(); IGCategorySeriesDataSourceHelper _source = new IGCategorySeriesDataSourceHelper(); public ChartCustomDataAxisLabelsViewController () {} public override void ViewDidLoad () { base.ViewDidLoad (); this.generateData(); _source.Data = _data.ToArray(); _source.ValuePath = @"Cost"; _source.LabelPath = @"Territory"; RectangleF chartRect = this.View.Frame; chartRect.Inflate(-30.0f, -30.0f); _chart.Frame = chartRect; _chart.AutoresizingMask = UIViewAutoresizing.FlexibleHeight|UIViewAutoresizing.FlexibleWidth; _chart.Theme = IGChartGradientThemes.IGThemeDark(); _chart.Delegate = new ChartViewDelegate(); this.View.Add(_chart); _chart.AddSeries(new MonoTouch.ObjCRuntime.Class("IGColumnSeries"), "series", _source, "xAxis", "yAxis"); } private void generateData() { String[] territories = new string[] {@"Canada", @"Finland", @"Holland", @"Japan", @"USA"}; for (int i = 0; i < 5; i++) { GraphObject graphObject = new GraphObject(); graphObject.Territory = territories[i]; graphObject.Cost = new Random(i).Next(100000); _data.Add(graphObject); } } }}
Thanks, that's exactly what I was looking for!
