Hi,If I have two menu items for my grids context menu, how can I return them both from the following override? Your documentation states:
// Return yes for every menu item that you want to be displayed, in this case, we just want our custom one.
Here is the routine in c#. How could I return two different items for the menu?
public override bool CanPerformActionForCell (IGGridView gridView, Selector action, IGCellPath path, NSObject sender) { return action == new Selector("sendEmail"); }thanks,Paul
Hi Paul,
The method fires every menu item, so you just need to OR the stmt for any additional selectors you want to support:
return action == new Selector("sendEmail") || action == new Selector("otherActon") || action == new Selector("action3");
I hope this helps clear things up.
-SteveZ
Steve,
As always, your answer clears this up perfectly. Thanks!
Paul
