Hi guys,
i would like to use infragistic on my MVC Application.
With your samples in webForm, i can use pagination, filter, sort, dynamic Add/Remove column with CustomDataBinding.
However i can't use summary with this function (with e.Cancel = true;) .
I'd like to set summary manually in code behind.
It's possible or is there another way to have all of this functionnalites ?
It's possible in MVC ?
Regards
Hello Adrian,
To calculate your own summary you can use the custom summary behavior as described in the following documentation:
http://help.infragistics.com/doc/ASPNET/2014.1/CLR4.0/?page=WebDataGrid_Adding_Custom_Summary.html
Concerning using the ASP.NET Ajax controls in MVC this isn’t supported as the ASP.NET Ajax controls are designed to work in a WebForms environment. MVC is a different patterned. If you are looking for controls to use in a MVC environment I recommend you look into our Ignite UI for jQuery Controls:
http://www.igniteui.com/
Please let me know if you have any further questions concerning this matter.
Thank you for your response.
I see Ignite UI.
