I have a WebHierarchicalDataGrid with paging behavior configured and it works ALMOST perfect. I can navigate forward and backward to any page index except to the default page index. I can go to the last page, and then go back one page, and then go back to the second page, and then go to the 5th page, etc.
The problem is when I make click in the initial page number (zero if is not specified in the attribute "PageIndex"). The grid disappears and the event PageIndexChanged is never fired on the server. I don't know what else to try, please, give me advice.
Thank you...
Hello Ricardo,
So far I am unable to replicate the described scenario using version 13.1 build 2157 under Ie7/8/9/10 and Firefox. Attached is my sample for your reference. Please feel free to modify it in order to illustrate the issue in question.
Do not hesitate to contact me with any updates or questions.
Please feel free to contact me if you are still experiencing any issues with this matter.
HI,
I have the same issue, the only difference we have is on Page_Load i have a condition checking if the request is post back.
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack) {
WebDataGrid1.DataSource = populateGrid(); WebDataGrid1.DataBind();
Its not executing on the default page defined, in my case it is page 1.
Thanks-JR
Hello JR,
In order for WebDataGrid's behaviors to function, the grid should be rebound on every postback. Does removing the !IsPostBack check make a difference ?
Do not hesitate to contact me with any questions.
