Hello.
I'm currently trying to apply a filter at runtime, using code-behind or in aspx.
This is how I'm coding in the aspx:
<ig:Filtering EnableInheritance="True">
<ColumnSettings>
<ig:ColumnFilteringSetting ColumnKey="Ano" />
</ColumnSettings>
<ColumnFilters>
<ig:ColumnFilter ColumnKey="Ano">
<ConditionWrapper>
<ig:RuleNumberNode Value="2012" />
</ConditionWrapper>
</ig:ColumnFilter>
</ColumnFilters>
</ig:Filtering>
And this is what I've been trying at the code-behind.
Private Sub GridNecessidadesRegaAnual_InitializeBand(sender As Object, e As Infragistics.Web.UI.GridControls.BandEventArgs) Handles GridNecessidadesRegaAnual.InitializeBand
Dim columnFilter As New ColumnFilter
Dim filtering As Filtering
filtering = Me.GridNecessidadesRegaAnual.Bands(0).Behaviors.Filtering
columnFilter.ColumnKey = "Ano"
columnFilter.Condition = New RuleNumberNode(TextFilterRules.Equals, 2012)
filtering.ColumnFilters.Add(columnFilter)
filtering.ApplyFilter()
End Sub
None of them seemed to work. The aspx code is just simply not working, the column shows with the filter, but it does nothing more. The code-behind gets me an error "Object reference not set to an instance of an object."
Can you help me, please?
Well, it seems that I managed to get it done using this code in the page load handler
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
If Not IsPostBack then
Dim columnfilter As ColumnFilter
columnfilter = New ColumnFilter(Me.GridNecessidadesRegaAnual.GridView)
columnfilter.ColumnKey = "Ano"
columnfilter.Condition = New RuleNumberNode(TextFilterRules.Equals, 2012)
Me.GridNecessidadesRegaAnual.GridView.Behaviors.Filtering.ColumnFilters.Add(columnfilter)
End If
I used a code sample that I found in InfragisticsNAforASPNETGridCheatSheet.pdf, but the same document refers two other code samples, one using the initializeband event and one other using the rowislandcreated event. None of them worked.
