Hello all,
I am current running into a number of problems with the WHDG after upgrading from Version 11.1 to Version 11.2.20112.2086.
I have created a sample application which replicates the problems experienced.
I have a grid bound to a flat dataset, with grouping enabled.
The grid uses a custom/templated grid pager.
The Issues are:
1. The server side events for Column Moving and Column Resizing does not fire.
This was working under Version 11.1.
2. When the grid pager view drop down list changes from a view with grouped columns back
to a flat / un-grouped view the control throws a XSLT error.
Further testing shown that it does not just relate to the grouped views, but to any selected view.
I hope that there are an obvious oversight which will resolve these issues quickly.
My environment is as follows:
VS2010
IE9
Widows 7 32 bit.
Infragistics ASP.Net Version 11.2.20112.2086
Regards.
Hello jcad,
I’ve taken a look at the attached sample but I couldn’t determine what causes the issues.
I also couldn’t reproduce the issues in a simplified scenario where your custom classes are not used.
Would it be possible for you to reproduce the issue in a simplified sample?
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
http://www.infragistics.com/support
Hello Maya,
Thank you for the reply.
Simplifying the sample serves no purpose. This is why a very simple example was forwarded to Infragistics. This already stripped down from a much more complex application.
Everytime issues are highlighted, the reply from Infragistics is to supply a simplified example. I have done this.
I fully expect a simple Infragistics example to not exhibit this behaviour as it does not mirror the "real-world" scenario.
The whole point of this sample is to mirror my implementation as closely as possible.
Could this be handed over to Developer support and a support case created?
I’ve created a case on your behalf. The case number is: CAS-86917-3NLRP1. We can continue communication trough there.
