Hi, we are using 10.1 version of webdatagrid and we are facing with next problem when we use Internet Explorer (Verified with IE9):
We set column width, order, etc and at the first load everything looks ok. Grid occupies full container width and columns extends for the whole width too. But after we aply some filter, the layout it lost, some columns are narrowed and an empty space appears at right. (I attach some pic which is self-explanative). If you click some of the button columns that we have set at the grid the layout is recovered.
If you have some idea about how to fix it we would really appreciate. In our opinion it seems that some error happens internally with the filter and the script which controls the grid rendering is stopped before load columns, but of course we are no tsure and also we dont know how to find or solve the exact problem.
Hi endaliadev,
I am so far not able to replicate the scenario. Can you provide some more information on how you are setting the widths of the grid and columns (i.e. in the markup or code-behind, in pixels or percentages). If I remember correctly from one of your other threads, you were using version 10.1 (it would also help to know which specific build is used in this case).
Please let me know if you have any additional questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://www.infragistics.com/support
Hi Petar. Exact dll versión is 10.1.20101.1011
I attach you the aspx code (extension has been renamed to .txt due to attach forum restrictions) which is causing problems.
By code and depending of some db conditions we are hiding some columns at the PageLoad event, but as I said at the first load the grid looks ok. The problem appears when we apply the filter.
Any help would be appreciated, if you need further information dont hesitate to ask for it, thanks!
Thank you for the sample code. After researching your code it seems that the hidden column in the grid is interfering with the filtering behavior (specifically in IE9). I tested the same scenario with version 10.1 build 2185 and could no longer reproduce the issue. I would strongly recommend you to consider upgrading your product version, as a number of issues have been resolved since the early releases of 10.1.
You may want to try assigning a width of 0 pixels to your hidden column to check if that affects the layout.
Please contact me if you have any questions.
Hi Petar
You are right, the problem appears when there are hidden columns :( we will try to solve it with the 0px solution (it will be difficult because introduces some new problems when you set some column visible again because you need to specify an specific width) and we will try to get the latest 10.1 version.
Please contact me if I can be of further assistance.
