Can you help me to achieve filtering in ig:TemplateDataField field.
If not possible then please give me alternate way to do it.
Hi omidixit,
A template data field is not bound to any data, so it is not possible to filter by default. What you can do is filter on a hidden column that is bound to the data that is actually showing in the templates. But you would need to implement the UI yourself as the Filtering behavior will not work on the template field. If your template is simple enough, you could try a FormatValueMethod or a DataFormatString.
regards,David Young
Can I have a sample code to demonstrate your suggestion?
