I have a WebDatagrid with about 20 columns. I need to export data to PDF format, so I used the WebDocumentExporter. This is my code:
Dim fileName As String = HttpUtility.UrlEncode("PDF") fileName = fileName.Replace("+", "%20") wdgPDFExporter.DownloadName = fileName With wdgPDFExporter .EnableStylesExport = True .DataExportMode = DataExportMode.DataInGridOnly .TargetPaperOrientation = Infragistics.Documents.Report.PageOrientation.Landscape .Margins = PageMargins.GetPageMargins("Narrow") .TargetPaperSize = PageSizes.GetPageSize("A4") .Export(wdg) End With
wdg is my WebDataGrid. Problems:
1) The page doesn´t show the Landscape format.
2) It does not show all the columns, only ones which fit on the page.
Somebody can help me?
Hi ilg,
Have you upgraded to the latest 10.3 Service Release? I think that there has been a bug fix made regarding the orientation.
regards,David Young
Hi AgentD5,
I am using very latest version i.e Version=13.2.20132.2077
I have 100 columns in webdatagrid . I set Paper size as "A4" but only 13 column shown in XPS viewer..
I dont want to increase my paper size. If remaining columns come ine next page then ok for me..
Please do the needful
I have attached sample code also
