Hello.
I use NetAdvantage 2008.2. My .ashx handler creates UltraWebGrid at run time,
populates data and then run export excel component. Everything works fine.
Now I need to calculate some cells with UltraCalcManager.
Is there a way to reference to UltraCalcManager at run time?
I tried to do something like that
uwcmCalc = new UltraWebCalcManager();
uwgExportGrid = new UltraWebGrid();
WGHExport.Calculator = uwcmCalc;
This doesnt work, null reference exception occures. Whats wrong?
Thanks in advance.
Hello Alekseya couple of months have passed since you asked this question but if you still need help of someone else from the community I would be glad if I can help. Please take a look at our online help referring to the control on the following link - http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Web_WebCalcManager.html There you can find part assigning Formulas At Run-Time part on the following address - http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebCalcManager_About_WebCalcManager.html
Unfortunately, NetAdvantage 8.2 is no longer supported by Infragistics Developer Support, and is no longer eligible for active maintenance or bug fixes. For information on the lifecycle of Infragistics products, please refer to the Product Lifecycle page via the following link:
<http://www.infragistics.com/support/productlifecycle.aspx>
You can refer to the installed product documentation and our online Knowledge Base for answers to the how-to questions that you may have. You can reach our Knowledge Base at the following link:
<http://devcenter.infragistics.com/Support/KnowledgeBase.Aspx>
You may be able to get assistance from other customers who have encountered similar issues in the past, using the peer-to-peer forums on our website. Please note that Infragistics Developer Support does not monitor these forums, and that answers provided are most likely coming from other users of the product. You can reach our peer-to-peer forums using the following link:
<http://news.infragistics.com/>
