I am following the example from https://www.infragistics.com/community/product_platforms/aspnet/w/aspnet-wiki/49/data-binding-the-webdatagrid-to-common-data-sources to bind to an ObjectDataSource. As it stands, it is working and I am also successful activating the cell editing and row adding behaviors. However, as soon as I use a MasterPage and put this within a Content, I receive "Deserialization failure: Invalid response" warnings on all add or edit actions. I have also added code-behind to assign the datasource dynamically. Can you help? Here is my code:
MASTER PAGE:
<%@ Master Language="C#" AutoEventWireup="true" CodeFile="MasterPage.master.cs" Inherits="MasterPage" %><%@ Register assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.NavigationControls" tagprefix="ig" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "">www.w3.org/.../xhtml1-transitional.dtd"><html xmlns="">www.w3.org/.../xhtml"><head runat="server"> <asp:ContentPlaceHolder id="_headPlaceHolder" runat="server"></asp:ContentPlaceHolder></head><body> <form id="form1" runat="server"> <div class="MenuSection"> <asp:ContentPlaceHolder id="_menuPlaceHolder" runat="server"> </asp:ContentPlaceHolder> </div> <div class="ContentSection"> <asp:ScriptManager ID="_scriptManager" runat="server"></asp:ScriptManager> <asp:ContentPlaceHolder id="_mainPlaceHolder" runat="server"></asp:ContentPlaceHolder> </div> </form></body></html>
ASPX PAGE (Default2.aspx):
<%@ Page Title="" Language="C#" AutoEventWireup="true" MasterPageFile="~/Admin/MasterPage.master" CodeFile="Default2.aspx.cs" Inherits="Admin_Default2" %><%@ Register assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.GridControls" tagprefix="ig" %>
<asp:Content ID="_mainContent" ContentPlaceHolderID="_mainPlaceHolder" runat="Server"> <asp:ScriptManagerProxy ID="_scriptManagerProxy" runat="server"> </asp:ScriptManagerProxy> <asp:ObjectDataSource ID="ObjectDataSource1" runat="server" SelectMethod="GetAllItems" TypeName="TestEntity" DataObjectTypeName="TestEntity" InsertMethod="SaveItem" UpdateMethod="SaveItem"></asp:ObjectDataSource> <ig:WebDataGrid ID="WebDataGrid1" runat="server" AutoGenerateColumns="False" Height="350px" Width="400px" DataKeyFields="Id"> <Columns> <ig:BoundDataField DataFieldName="Id" Key="Id"><Header Text="Id" /></ig:BoundDataField> <ig:BoundDataField DataFieldName="TestProperty" Key="TestProperty"><Header Text="TestProperty" /></ig:BoundDataField> </Columns> <Behaviors> <ig:EditingCore> <Behaviors><ig:CellEditing></ig:CellEditing><ig:RowAdding></ig:RowAdding><ig:RowDeleting /></Behaviors> </ig:EditingCore> <ig:Selection CellClickAction="Row" RowSelectType="Single"></ig:Selection> <ig:RowSelectors></ig:RowSelectors> </Behaviors> </ig:WebDataGrid></asp:Content>
CODE-BEHIND:
using System;using System.Collections.Generic;using System.Linq;using System.Web;using System.Web.UI;using System.Web.UI.WebControls;
public partial class Admin_Default2 : System.Web.UI.Page{ protected void Page_Init(object sender, EventArgs e) { WebDataGrid1.DataSource = ObjectDataSource1; }}
CUSTOM OBJECT (in App_Code):
public class TestEntity{ private static List<TestEntity> _list = new List<TestEntity>();
public long Id { get; set; } public string TestProperty { get; set; }
static TestEntity() { _list.Add(new TestEntity() { Id = 1, TestProperty = "A" }); _list.Add(new TestEntity() { Id = 2, TestProperty = "B" }); }
public TestEntity() { }
public List<TestEntity> GetAllItems() { return _list; }
public int SaveItem(TestEntity instance) { int indexFound = -1; foreach (TestEntity entity in _list) if (entity.Id == instance.Id) indexFound = _list.IndexOf(entity); if (indexFound > -1) _list[indexFound] = instance; else _list.Add(instance); return 1; }}
html xmlns
head runat
="server">
head
body
<div class
="MenuSection">
</div
="ContentSection">
</form
html
Oups... sorry for the long snippet I accidentally left in the text.
MORE IMPORTANTLY... I noticed I had not provided the MasterPage.Master.cs contents. When I went to copy it, I realized I had a Page_Init piece of code to change the master page ID to "_master" (rather than the default "ctl00"). After I removed that, the warnings disappeared.
