I need barspacing to be half of the width of bars in Barchart. When I am trying to assign a value to Barspace it takes integer value and assigning 1 makes the barspace space equal to bar width.
Please suggest how I can make barspace = 0.5 * Bar width.
You can set the BarSpacing and SeriesSpacing to 0 and correct the height of the bars in the ChartDrawItem event. Try using this code:
this.UltraChart1.ChartType = ChartType.BarChart;
this.UltraChart1.BarChart.BarSpacing = 0;
this.UltraChart1.BarChart.SeriesSpacing = 0;
UltraChart1.DataSource = DemoTable.AllPositive();
UltraChart1.DataBind();
this.UltraChart1.ChartDrawItem += UltraChart1_ChartDrawItem;
private void UltraChart1_ChartDrawItem(object sender, ChartDrawItemEventArgs e)
Box box = e.Primitive as Box;
if (box == null || box.DataPoint == null)
return;
int diff = (int)(box.rect.Height / 6.0);
box.rect.Y += diff;
box.rect.Height -= 2 * diff;
