I have a 3 level WHDG bound to an IEnumerable datasource and cannot get sorting to work with paging.
I have set the datakeyfields for each band as noted in this article ( https://www.infragistics.com/help/aspnet/webhierarchicaldatagrid-sorting )
Sorting seems to work on page 1 but on subsequent paging (2, 3,...) the sort does not persist.
Also, when on page 2, a sort operation results in the active page going back to pg1 with the sort performed.
Any ideas anyone? Thanks in advance.
Charlie
Hello Charlie,
I checked the behavior and I was able to reproduce it.
I guess that the issue is caused by the paging.
I created a new support case on your behalf (CAS-56634-VPPYSG) and I will investigate this further.
Tsvetlina,
Wsa there a fix done for this? I have the same issue
