quick rundown of what im doing, i have a list of Parents with Children as normal, both the parents and children have macaddresses (field mac), the children are associated to the parents by a field "assocmac" ... the issue is i needed a way to search both the parents and children for a mac, filtering doesnt really do this as it is because its only by group, i need to filter out the entire source
what i did was create a textbox with a button where i can enter a part of an address and it will search both databases and then update the sqldatasources and rebind the whdg...
problem is that after it searches, the parents get filtered (i see them all but only the ones with children matching the criteria have drop down arrows... but when i click the drop down arrow it shows all the children not the filtered ones from my filtered datasource.... and if i click to sort a column on the parent.. tada all of the parents now have drop downs....
its as if somewhere its loosing the changes i made to the datasources
page is just 2 sqldatasources, 1 whds and 1 whdg here is the actual code im using on the button press
Dim ap As Boolean = False
Dim ObjConnection As New SQLiteConnection(connString)
Dim ObjCommand As New SQLiteCommand("select mac from aps where mac like '%" & WebTextEditor1.Text & "%'", ObjConnection)
ObjCommand.CommandType = CommandType.Text
ObjConnection.Open()
Dim i As String = ObjCommand.ExecuteScalar
If i = "" Then
ObjCommand.CommandText = "select assocmac from clients where mac like '%" & WebTextEditor1.Text & "%'"
i = ObjCommand.ExecuteScalar
Else
ap = True
End If
ObjConnection.Close()
ObjCommand.Dispose()
ObjConnection.Dispose()
If ap = True Then
SqlDataSource1.SelectCommand = "SELECT * FROM [APs] where mac like '%" & WebTextEditor1.Text & "%'"
SqlDataSource2.SelectCommand = "SELECT * FROM [CLIENTs]"
SqlDataSource1.DataBind()
SqlDataSource2.DataBind()
WebHierarchicalDataGrid1.Rows.Clear()
WebHierarchicalDataSource1.DataBind()
WebHierarchicalDataGrid1.DataBind()
SqlDataSource1.SelectCommand = "SELECT * FROM [APs]"
SqlDataSource2.SelectCommand = "SELECT * FROM [CLIENTs] where mac like '%" & WebTextEditor1.Text & "%'"
Hi cchance,
It has been a while since your post, however in case you are still in need of assistance I would be glad to help.
You are presenting a very interesting scenario regarding filtering in the WebHierarchicalDataGrid. The approach you have employed is on the right tracks, however as far as I understand you are filtering your data source on the button click only.
Note that the grid is rebound to its data source on every postback. Furthermore, if you are otherwise binding the grid from your markup, on every postback which is not caused by your by button being clicked, the data source is repopulated to its original state. Hence you should manually ensure the consistency of your data source on every Page_Load.
Please contact me if you have any questions.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://www.infragistics.com/support
