Can you add or remove items from the menu, when being used as a context menu, through javascript?
Hello Doug,
Unfortunatelly this feature is not currently implemented. A possible solution for you is to have separate WebDataMenu instances, set as context menus, and call the showAt() method on the appropriate one of them.
