I have deployed a page to our server and the images are not showing up on the WebDataGrid unless I upload the ig_res folder to the web server. I have copied the files to the server and created a virtual directory that points to ig_common. The missing image is still trying to access the ig_res folder (/ig_res/Default/images/igg_sortAsc.gif). Any help would be great.
Jeff
If I understand right you've copied files with Styles add a virtual directory, whichs is listing when you type something like this: http://localhost/ig_common/ in your browser a list of themes appears? But the styles are not applied?
If that is the case, you have to modify web.config file and you have to add the following linesof code:
<configSections> <
section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/> </
configSections> <
infragistics.web styleSetName="Default" styleSetPath="http://localhost/ig_common/"/>
That code have to be placed inside the <configuration> tag, but before <system.web> tag.
Hope that helped
Thanks you pointed me in the right direction. I wasn't aware that the style images are not part of ig_common. I added them to the virtual directory and was good to go.
thanks
