I have created a composite line chart that displays multiple line chart layers which plot OK but the final data label on the X-Axis is not shown. In a different composite chart I have a column layer with multiple line layers and this works as expected. Additionally, in the line chart
The difference seems to be that the composite chart with the column layer uses SetLabelAxisType.GroupBySeries whereas the chart with only line layers uses SetLabelAxisType.ContinuousData.
Adding a null datapoint as described here https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/38268/adding-composite-column-chart-with-different-series-data/222803#222803 solves my problem but leaves the graphs with a different look.
I was wondering if there I was missing something or indeed if the above solution is the only way around this.
Here's how I create my X-Axis
AxisItem axisX = new AxisItem();
axisX.OrientationType = AxisNumber.X_Axis;
axisX.DataType =
AxisDataType.String;
axisX.SetLabelAxisType =
SetLabelAxisType.ContinuousData;
axisX.Labels.ItemFormat =
AxisItemLabelFormat.ItemLabel;
axisX.Labels.Orientation = TextOrientation.VerticalLeftFacing;
axisX.Labels.Layout.Behavior = AxisLabelLayoutBehaviors.Auto;
Matt
Can you send us your project, so we can look at it more closely? Also you can try applying the latest service releases. We fixed some issues like yours, but I'm not sure if this is something different.
