I have a chart and when there are multiple rows in the dataset everything works fine. When there is one row in the dataset the labels are what they should be but the barchart does not fill. Is there a reason why this is?
Here is my code:
DataTable dt = new DataTable(); UltraChart1.ChartType = ChartType.BarChart; ChartArea area = new ChartArea(); area.PE.FillGradientStyle = GradientStyle.Default; UltraChart1.CompositeChart.ChartAreas.Add(area); UltraChart1.ColorModel.ModelStyle = Infragistics.UltraChart.Shared.Styles.ColorModels.CustomLinear; Color[] ChartColors; ChartColors = new Color[] {Color.Blue}; UltraChart1.ColorModel.CustomPalette = ChartColors; AxisItem xAxisColumn = new AxisItem(this.UltraChart1, AxisNumber.X_Axis); AxisItem yAxis = new AxisItem(this.UltraChart1, AxisNumber.Y_Axis); xAxisColumn.DataType = AxisDataType.String; xAxisColumn.Labels.ItemFormat = AxisItemLabelFormat.ItemLabel; yAxis.DataType = AxisDataType.Numeric; yAxis.RangeType = AxisRangeType.Custom; xAxisColumn.Labels.Orientation = TextOrientation.Horizontal; area.Axes.Add(xAxisColumn); area.Axes.Add(yAxis); ChartLayerAppearance columnLayer = new ChartLayerAppearance(); columnLayer.AxisX = xAxisColumn; columnLayer.AxisY = yAxis; columnLayer.ChartArea = area; columnLayer.ChartType = ChartType.BarChart; ChartLayerAppearance lineLayer = new ChartLayerAppearance(); this.UltraChart1.CompositeChart.ChartLayers.Add(columnLayer); this.UltraChart1.ColumnChart.SeriesSpacing = 0; this.UltraChart1.DataSource = ds.Tables[0]; this.UltraChart1.DataBind();
<igchart:UltraChart ID="UltraChart1" runat="server" BackgroundImageFileName="" BorderWidth="0px" ChartType="BarChart" EmptyChartText="Data Not Available. Please call UltraChart.Data.DataBind() after setting valid Data.DataSource" Version="6.3" BackColor="#F4F6FF" BorderColor="Black" Legend-BackgroundColor="#F4F6FF" Width="600px" Height="500px"> <Axis>
<X LineThickness="1" TickmarkInterval="0" TickmarkStyle="Smart" Visible="True"> <%-- <MinorGridLines AlphaLevel="255" Color="LightGray" DrawStyle="Dot" Thickness="1" Visible="False" /> <MajorGridLines AlphaLevel="255" Color="Gainsboro" DrawStyle="Dot" Thickness="1" Visible="True" />--%> <Labels Orientation="horizontal" VerticalAlign="Center" > <Layout Behavior="Auto"> </Layout> <SeriesLabels Font="Verdana, 7pt" FontColor="Gray" FormatString="" HorizontalAlign="Near" Orientation="horizontal" VerticalAlign="Center"> <Layout Behavior="Auto"> </Layout> </SeriesLabels> </Labels> </X>
<PE Fill="cornsilk" /></Axis>
<DeploymentScenario ImageURL="../../../ChartImages/Chart_#SEQNUM(100).png" /> </igchart:UltraChart>
in this case, the bar is just up against the y-axis. try setting
UltraChart1.Data.ZeroAligned = true;
or setting Axis.X.RangeType = Custom and setting a RangeMin and RangeMax.
That worked. Thanks a lot.
