Hi, I recently upgraded the version of Infragistics in an application from 5.3.20053.1099 to 5.3.20053.50. Everything seems to be working as it had before by just upgrading the version numbers except for my UltraWebChart. It is being set to a data table, and the data is getting bound, however it will only plot the first point in the table. Was there anything specifically changed that I now need to call for it to plot the remaining points? Again no code changes were made, the only difference is the Infragistics version, and the plots had been plotting perfectly before.
Thanks!
Vanessa
Okay I did find some more information about my problem:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=8689
Does anyone know of a workaround for this, other than just upgrading?
it has been a long while since i fixed this... but i think if you use the Series collection as a datasource, it will circumvent this problem.
also note that 5.3.20053.1099 -> 5.3.20053.50 is a downgrade, not an upgrade -- 1099 is the later (hotfix) version.
Okay, thank you so much, I will try that!
I was wondering about that version number. This app was not written by me, and so, when I started tinkering with it, it was on the 1099 version. Well, the dlls on our build server are 50, so they had me "upgrade" or I guess rather "downgrade" to the 50 version.
I really appreciate your quick response, as there isn't much documentation out for these versions anymore.
Thank you!
