209
WebDataMenu with SiteMapDataSource loses place in path
Infragistics 9.1 .Net 3.5  When selecting a WebDataMenu item with a SiteMapDataSource, where the site map has several levels of hierarchy, a second time, the control seems to lose it's root.
If I have a site map with subdirectories ...
Help/About.aspx for example -- the first click will produce url .../Help/About.aspx ... but while on the About.aspx page, when I click the same menu item it produces an incorrect url .../Help/Help/About.aspx.
I have tried prepending with a ~ which produces .../Help/~/Help/About.aspx, a /, which then causes the menu item to not be rendered, and .. which then causes the first click to go back a directory and it then can't find the Help sub directory.
Is there a setting or prefix character that can be used to set the right path?
Parents Reply Children
No Data
