Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
(1) Is it possible to provide pagination in sub band grids (child grids) under the main grid ?
This feature is not present in WebGrids (2008 version)
(2) Moreover I was not able to create below mentioned structure using UltraWebGrid (as child to parent grid relation was missing .. unless I make my MainInfoTag same as AssetTag1/2/3) is it possible to use WebHierarchicalDataSource to create this grid ?
Main --> level1
MainInfoTag --> level2
GridHavingMainInformation --> Sub grid @ level3
OtherMainInfoTag à level2
GridHavingOtherMainInformation--> Sub grid @ level3 (can I have pagination here?)
AssetsTag1 --> level2
SubAssetsTag1 --> level3
GridHavingAssetsRelatedInformation --> Sub Grid @ level 4
SubAssetsTag2 --> level3
ChildSubAssetTag3 --> level 4
GridHavingChildAssetsRelatedInformation --> Sub Grid @ level 5
AssetsTag2 --> level2
AssetsTag3 --> level2
All the grids - GridHavingMainInformation / GridHavingOtherMainInformation / GridHavingAssetsRelatedInformation and GridHavingChildAssetsRelatedInformation have different column sets !
Any help to the problem will be much appreciated!
This grid does not support hierarchy yet. When the feature comes out, we'll make sure it does support pagination in the child rows.
Thank you!
One more thing -- instead of pagination @ sub grid level, can I have a scroll ?
The UltraWebGrid support hierarchy, you might want to check it out. No pagination or scrollbars on the child rows is availabe there either though.
