I have 2 strange issues with my webdropdown.
1. All items displayed in the dropdown have an underscore
2. When the dropdown is multi select, and I select multiple items, the selected items are comma seperated visible in the control. But when the selected values get longer than the width of the dropdown control, the text is going outside of the control.
This does not happen with the infragistics examples . What am I doing wrong?
Thanks for your help
Jeroen
Looks like styles are not applied correctly - or they are not applied in general . Which browser do you use (not that it should matter from what I can see in the screenshot).
Did you make any modifications to the CSS stylesheets or StyleSets ? If you could show me your ASPX code i am sure i can help more.
Thanks for the feedback,
Angel
Hi Angel,
Thanks for pointing me in the right direction. The problem is solved now. It was caused by not having a StyleSetName defined on the controls and the default StyleSetName was one from an older version.
