Does anyone have any VB.net examples of how to add control limits to a line chart? I have a line chart with data aligned to dates and I want to add a red dashed line as a lower control limit and upper control limit (both perpendicular to the Y axis).
I tried using StripLines but can't get it to work.
Me.UltraChart2.Axis.Y.StripLines.Interval.MinValue = 0
Me.UltraChart2.Axis.Y.StripLines.Interval.MaxValue = 0.3
Thanks!
Private Sub UltraChart1_FillSceneGraph(ByVal sender As Object, ByVal e As FillSceneGraphEventArgs) Handles UltraChart1.FillSceneGraph ' we want to insert the control limit box before any of the axis gridlines, so let's start by getting the index of the first gridline Dim indexOfFirstGridline = -1 For current As Integer = 0 To e.SceneGraph.Count - 1 Dim currentPrimitive As Primitive = e.SceneGraph(current) If TypeOf currentPrimitive Is Line Then ' we have found an axis gridline. indexOfFirstGridline = current Exit For End If Next If indexOfFirstGridline = -1 Then Return ' failed ' get references to the axis objects Dim yAxis As IAdvanceAxis = CType(e.Grid("Y"), IAdvanceAxis) Dim xAxis As IAdvanceAxis = CType(e.Grid("X"), IAdvanceAxis) Dim startX As Integer = xAxis.MapMinimum Dim endX As Integer = xAxis.MapMaximum Dim startY As Integer = yAxis.Map(0.0) Dim endY As Integer = yAxis.Map(0.3) Dim controlLimitBox As New Box(New Rectangle(startX, endY, endX - startX, startY - endY)) controlLimitBox.PE = New PaintElement(Color.Pink) e.SceneGraph.Insert(indexOfFirstGridline, controlLimitBox) End Sub
