How to use pagination in infragistics V21 for webdatagrid?
Please help me!!
Thanks in advance!!
I have been looking into your question and what I could suggest is to take a look at our ASP.NET online samples where could be found implementations of some common scenarios.
A sample with paging could be found here.
In addition, a topic that you might consider helpful could be found here.
Let me know if I may be of any further assistance.
Sincerely,Teodosia HristodorovaSoftware Developer
I implemented the same but css is not working it is only showing numbers and the functionality is working fine.
and not showing selected page.
A possible reason for such behavior could be if the ig_res folder is missing, so please make sure it is included into the project.
I have prepared a small sample with enabled paging and on my side, everything works and looks as expected.
It could be found attached below. Please test it on your side and let me know if I may be of any further assistance.
3056.WDG_paging.zip
Where I can download ig_res?
Normally, the ig_res folder gets created when you go into the design view of your aspx.
However, you could manually create and add this folder which contains images and CSS files located in the Infragistics ASP.NET installation folder or copy it from here.
Once you copy the ig_res folder into your solution, use the “Show All Files” option in the solution explorer, right-clicking on the ig_res folder and select the “Include in Project” option. Thus, the folder would be included in the project and the styles would be applied.
