hi ,
how can i disable a column from code behind and change it color to yellow
thank you.
You can set the different color of a column by setting CssClass property. You can look for it in this forum post:
https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/57539/how-to-set-webdatagrid-s-column-background-color-with-code-behind
If you want to disable editing of a column you have to add this column in editing columns setting and to set ReadOnly property to true. You can look at this link for more details:
https://www.infragistics.com/help/aspnet/webdatagrid-setting-column-settings-for-a-behavior
