445
Sorting and Filtering DateTime field in WebDataGrid
I'm using a WebHierarchicalDataGrid which has a DateTime field to be bound. I have enabled sorting and filtering. When I execute the page I'm getting the following error message.
The filtering rule condition of type Infragistics.Web.UI.GridControls.RuleNumberNode is not an appropriate type for column <Column Name>, which is of type System.DateTime.
It's working fine if I removed the filtering at all. But I need filtering as well. I tried converting my DateTime field in the stored procedure as "CONVERT( VARCHAR(10), I.InvoiceDate, 101)". Then it's working fine, but the sorting is happening wrongly for this column.
I also tried adding ColumnFilters with the RuleDateNode for the grid as follow, but it still throws the same error.
<ig:Filtering>
    <ColumnFilters>
        <ig:ColumnFilter ColumnKey="InvoiceDate">
            <ConditionWrapper>
                <ig:RuleDateNode Rule="Equals"/>
            </ConditionWrapper>
        </ig:ColumnFilter>
    </ColumnFilters>
</ig:Filtering>
My ultimate goal is to have both Sorting and Filtering for my DateTime field and I'm wondering how Infragistics does not have this. How can I achieve this?
Parents Reply Children
No Data
