QTP not able to recording but identifies the objects with the help of "OBJECT SPY".
--> Suppose If i write Descriptive program while running it throughs the error.
Error :
Could not load file or assembly “ Infragistics2.Win.v10.2, Version=10.0.20102.9000, Culture=neutral,
PublicKey Token=7dd5c3163f2cd0cb” or one of its dependencies. The system cannot find the file specified.
Hi Karnihs,
My first thought for this is that you are using the latest version of TestAdvantage but your application that you are testing against is using an older version of NetAdvantage. As stated in greater detail in the following link, when testing an application using Infragistics controls, the version of TestAdvantage must match the version of NetAdvantage :https://www.infragistics.com/community/forums/f/test-automation-for-micro-focus-uft-windows-forms/45009/testadvantage-versions-support-in-netadvantage-versions/244385#244385
Let me know if this helps,
