I am working with QTP 10 installed in TA 9.2 in my machine. It his identifying the application when run it manually but due to batch running process we trigger QTP through vb script
Set oQTP = CreateObject("QuickTest.Application") and we are making sure all the add-ins are loaded by using the below code
aAddins = oQTP.GetAssociatedAddinsForTest(sDriver)
and loading all the required add-ins for the test. then when i launch my application thro QTP and try to operate on it, the objects are identified as Window and win objects instead of Swfwindow and swf controls. This does not happen if I open QTP manually and run the same test. Kindly provide resolution for this thank you.
The behavior you are seeing indicates that either the .NET Add-In isn't loaded or maybe that you are doing low level recording.
Since the Window is being recognized as Window rather than SwfWindow, I would expect the same results if you were to disable TestAdvantage and perform the same test again. Please test this and if you find that the same result occurs, you should contact HP support for this issue as the issue is with loading the HP .NET Add-In.
If you find that the behavior is different with TestAdvantage disabled, please provide me with a script demonstrating more of what you are doing that I can run to test this on my end. The script that you provide me should work with one of the samples that come with TestAdvantage. On Windows XP, the samples are found in the following location:
C:\Documents and Settings\All Users\Documents\Infragistics\TestAdvantage for Windows Forms (HP) 2009.2\Samples\
Let me know if you have any questions with this matter.
Sincerely,AlanDeveloper Support SupervisorInfragisticswww.infragistics.com/support
hi,
hope this comparision will prove that infragistic dlls are not loaded properly if Set oQTP = CreateObject("QuickTest.Application") method of lauching QTP and nothing to do with dot net add-in so pls let me know any resolution for this. thank you.
When you disabled TestAdvantage and tested with the installed samples and objects were identified as window, which sample were you testing on? By "either my normal method of opening QTP manually or using vb script method" are you saying that even when opening QTP manually that the application was recognized as Window rather than SwfWindow?
If using QTP with TestAdvantage disabled reproduced the issue with the application being recognized as Window rather than SwfWindow, then TestAdvantage shouldn't be a factor as the mappings for the record/replay servers wouldn't be in the SwfConfig.xml file so the .NET Add-In wouldn't even attempt to load the TestAdvantage assemblies.
What environment are you running the VB script that opens QTP and can you provide the full script that you are using and steps to reproduce the issue so that I may test this on my end.
Alan
