I am testing TestAdvantage trial version using QTP 9.5 for a .NET windows based application but it is not recognizing any of the objects:
Infragistics.Win.UltraWinToolbars
Infragistics.WinUltraWinGrid
Ingragistocs2.Win.UltraWinTabControl
The other objects are recognized as swf. Any idea if this tool works for this specific scenario ?
Alba
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
Make sure volume of TestAdvantage matches with the volume of NetAdvantage used in your application and configured properly
I will have to request the NetAdvantage information from the vendor of the software. The trial version that I downloaded of TestAdvangate is for Windows Forms (HP) 2009.1.
Where can I check the compatibilty between them ? Should I open a direct question to Infragistics ?
Thanks for you suggestion.
Alba,
I am assuming you are looking to verify that the version of TestAdvantage you have is compatible with the version of NetAdvantage used in the AUT. If this is the case, then the version of TestAdvantage needed is the same Year and Volume as the NetAdvantage version used in the AUT. For example if the AUT was developed with NetAdvantage 2009 Volume 1, then you would need to use TestAdvantage 2009 Volume 1.
Alan
